Ir para o conteúdo principal
Nokia 6236i Front Casing Replacement
O que você precisa
  1. Nokia 6236i Front Casing Replacement, Battery: passo 1, imagem 1 %32 Nokia 6236i Front Casing Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Nokia 6236i Front Casing Replacement: passo 2, imagem 1 %32 Nokia 6236i Front Casing Replacement: passo 2, imagem 2 %32 Nokia 6236i Front Casing Replacement: passo 2, imagem 3 %32
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Nokia 6236i Front Casing Replacement, SIM Card: passo 3, imagem 1 %32 Nokia 6236i Front Casing Replacement, SIM Card: passo 3, imagem 2 %32 Nokia 6236i Front Casing Replacement, SIM Card: passo 3, imagem 3 %32
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Nokia 6236i Front Casing Replacement, Front Casing: passo 4, imagem 1 %32 Nokia 6236i Front Casing Replacement, Front Casing: passo 4, imagem 2 %32 Nokia 6236i Front Casing Replacement, Front Casing: passo 4, imagem 3 %32
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
Conclusão
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Erik Lindahl
Membro desde: 04/18/10
63 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 10-46, Garner Spring 2010 Membro de Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 1,861
