Ir para o conteúdo principal
Nokia 6200 Classic Circuit Board Replacement
O que você precisa
  1. Nokia 6200 Classic Circuit Board Replacement, Front Plate: passo 1, imagem 1 %32 Nokia 6200 Classic Circuit Board Replacement, Front Plate: passo 1, imagem 2 %32 Nokia 6200 Classic Circuit Board Replacement, Front Plate: passo 1, imagem 3 %32
    • Pull up on both of the clips near the bottom of the phone as shown.
    • Lift off the front plate.
  2. Nokia 6200 Classic Circuit Board Replacement: passo 2, imagem 1 %32
    • The keypad and LCD screen are revealed.
  3. Nokia 6200 Classic Circuit Board Replacement, Circuit Board: passo 3, imagem 1 %32 Nokia 6200 Classic Circuit Board Replacement, Circuit Board: passo 3, imagem 2 %32
    • Separate the keypad from the phone and place aside.
    • Wipe off any excess dust from where the keypad was attached to the phone.
  4. Nokia 6200 Classic Circuit Board Replacement: passo 4, imagem 1 %32 Nokia 6200 Classic Circuit Board Replacement: passo 4, imagem 2 %32
    • Remove the 6 - 7.9 mm screws highlighted by the markers using the T-6 head on the screwdriver.
  5. Nokia 6200 Classic Circuit Board Replacement: passo 5, imagem 1 %32 Nokia 6200 Classic Circuit Board Replacement: passo 5, imagem 2 %32
    • Separate the inside of the phone from the back of the phone.
  6. Nokia 6200 Classic Circuit Board Replacement: passo 6, imagem 1 %32 Nokia 6200 Classic Circuit Board Replacement: passo 6, imagem 2 %32
    • Gently pull apart the circuit board from the rest of the phone.
    • There is a small connector holding these two pieces together, so use caution when pulling apart so as not to damage it.
Conclusão
To reattach the circuit board, line up the connector at the top of the board with the back of the LCD Screen attachment. Place the two boards together, and screw in the 6 screws.
Reid Polstra
Membro desde: 10/22/12
1 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 15-5, Benson Fall 2012 Membro de Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 11
Duração total: 776
