Ir para o conteúdo principal
Nokia 6200 Classic Battery Replacement
  1. Nokia 6200 Classic Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone so it is face down (keypad side is down).
  2. Nokia 6200 Classic Battery Replacement: passo 2, imagem 1 %32 Nokia 6200 Classic Battery Replacement: passo 2, imagem 2 %32 Nokia 6200 Classic Battery Replacement: passo 2, imagem 3 %32
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Nokia 6200 Classic Battery Replacement: passo 3, imagem 1 %32 Nokia 6200 Classic Battery Replacement: passo 3, imagem 2 %32 Nokia 6200 Classic Battery Replacement: passo 3, imagem 3 %32
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
Conclusão
To replace the battery, simply put a new battery in the back of the phone, and replace the back cover.
Reid Polstra
Membro desde: 10/22/12
1 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 15-5, Benson Fall 2012 Membro de Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,110
