Ir para o conteúdo principal
Nokia 6102i motherboard replacement
O que você precisa
  1. Nokia 6102i motherboard replacement, Battery: passo 1, imagem 1 %32 Nokia 6102i motherboard replacement, Battery: passo 1, imagem 2 %32 Nokia 6102i motherboard replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i motherboard replacement: passo 2, imagem 1 %32
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Nokia 6102i motherboard replacement, Logic Board: passo 3, imagem 1 %32 Nokia 6102i motherboard replacement, Logic Board: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    T6 Torx Screwdriver
    $9.99
    Comprar
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  4. Nokia 6102i motherboard replacement: passo 4, imagem 1 %32 Nokia 6102i motherboard replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  5. Nokia 6102i motherboard replacement: passo 5, imagem 1 %32 Nokia 6102i motherboard replacement: passo 5, imagem 2 %32
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  6. Nokia 6102i motherboard replacement: passo 6, imagem 1 %32 Nokia 6102i motherboard replacement: passo 6, imagem 2 %32
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
Conclusão
Alex Graebe
Membro desde: 04/15/10
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 23-78, Johann Spring 2010 Membro de Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,633
