Introdução
Use this guide to remove and repair the logic board.
O que você precisa
Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
Note: Images on the right side may be hovered over to reveal larger versions.
Ferramenta utilizada nesse passo:T6 Torx Screwdriver$9.99
Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
