Ir para o conteúdo principal
Nokia 6102i Keyboard Replacement
O que você precisa
  1. Nokia 6102i Keyboard Replacement, Battery: passo 1, imagem 1 %32 Nokia 6102i Keyboard Replacement, Battery: passo 1, imagem 2 %32 Nokia 6102i Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6102i Keyboard Replacement: passo 2, imagem 1 %32
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6102i Keyboard Replacement, Logic Board: passo 3, imagem 1 %32 Nokia 6102i Keyboard Replacement, Logic Board: passo 3, imagem 2 %32
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6102i Keyboard Replacement: passo 4, imagem 1 %32 Nokia 6102i Keyboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6102i Keyboard Replacement: passo 5, imagem 1 %32 Nokia 6102i Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6102i Keyboard Replacement: passo 6, imagem 1 %32 Nokia 6102i Keyboard Replacement: passo 6, imagem 2 %32
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6102i Keyboard Replacement, Keyboard: passo 7, imagem 1 %32 Nokia 6102i Keyboard Replacement, Keyboard: passo 7, imagem 2 %32
    • Pop out the keyboard from the frame.
    • Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
    • The picture is showing the three layers: the frame, the keyboard, and the logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 23-78, Johann Spring 2010 Membro de Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 2,187
