Ir para o conteúdo principal
Nokia 6102i Inside Display Screen Replacement
O que você precisa
  1. Nokia 6102i Inside Display Screen Replacement, Inside Display Screen: passo 1, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement, Inside Display Screen: passo 1, imagem 2 %32
    • This step does not require much force.
    • With the screen facing up, connect the display connector to the smaller of the open connectors on the motherboard.
  2. Nokia 6102i Inside Display Screen Replacement: passo 2, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement: passo 2, imagem 2 %32
    • Place the metal case over the top of the screen so that it snaps into place.
  3. Nokia 6102i Inside Display Screen Replacement: passo 3, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement: passo 3, imagem 2 %32 Nokia 6102i Inside Display Screen Replacement: passo 3, imagem 3 %32
    • Insert the circuitboard into the back of the phone, with the inside screen facing down.
    • Lightly press down on the left hand corner so the circuitboard attaches to the phone.
  4. Nokia 6102i Inside Display Screen Replacement, Cover: passo 4, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement, Cover: passo 4, imagem 2 %32 Nokia 6102i Inside Display Screen Replacement, Cover: passo 4, imagem 3 %32
    • Snap the top cover into place so that the outside screen is visible. Press around the perimeter to secure the case.
  5. Nokia 6102i Inside Display Screen Replacement: passo 5, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement: passo 5, imagem 2 %32
    • Open the phone and insert the screws tightly.
  6. Nokia 6102i Inside Display Screen Replacement: passo 6, imagem 1 %32 Nokia 6102i Inside Display Screen Replacement: passo 6, imagem 2 %32
    • Snap on the black piece over the exposed screws.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Danielle
Membro desde: 09/27/12
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-3, Buehl Fall 2012 Membro de Ohio State, Team 1-3, Buehl Fall 2012
OSU-BUEHL-F12S1G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 542
