Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing a faulty vibrator.
O que você precisa
Turn off the phone.
Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
Position the phone so that the back side is in view.
Turn the phone so that the back of the phone is facing forward.
The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
Locate the four screws.
Remove the screws using a T6 Torx screwdriver.
