Ir para o conteúdo principal
Nokia 6086 Battery Replacement
O que você precisa
  1. Nokia 6086 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: passo 2, imagem 1 %32 Nokia 6086 Battery Replacement: passo 2, imagem 2 %32 Nokia 6086 Battery Replacement: passo 2, imagem 3 %32
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: passo 3, imagem 1 %32 Nokia 6086 Battery Replacement: passo 3, imagem 2 %32 Nokia 6086 Battery Replacement: passo 3, imagem 3 %32
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
Conclusão
Andrea
Membro desde: 04/15/10
70 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 26-30, Regan Spring 2010 Membro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 3,845
