Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Replacing LCD Screen.
Peças
Nenhum componente especificado.
  1. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
    • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
    • Use your fingernail and gently pull the the bottom of the battery up.
    • Lift out battery and remove.
  3. Use your fingernail to lift the metal cage up. Remove SIM card. Remove SIM card.
    • Use your fingernail to lift the metal cage up.
    • Remove SIM card.
  4. Close the metal cage.
    • Close the metal cage.
  5. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
    • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  6. After removing the top cover, turn the phone over so the screen is facing upwards. After removing the top cover, turn the phone over so the screen is facing upwards.
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows.
    • Lift the front off the phone by pulling above the arrows.
  8. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver.
    • Remove the six screws with a T-6 Torx screwdriver.
  9. Gently lift the top of the screen up. Be cautious of loose parts. Be cautious of loose parts.
    • Gently lift the top of the screen up.
    • Be cautious of loose parts.
  10. Gently pull up on the grey plastic tab. Gently pull up on the grey plastic tab. Gently pull up on the grey plastic tab.
    • Gently pull up on the grey plastic tab.
Conclusão
2 outras pessoas concluíram este guia.
Spencer Woodworth
Membro desde: 14/04/2010
316 Reputação
9 Guias de autoria
Equipe
Cal Poly, Team 23-63, Johann Spring 2010 Membro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Membros
17 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 6,574
