Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing the keypad.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
Gently pull the rubber away from the the front screen and all the buttons will go with it.
Uma outra pessoa concluiu este guia.
