Introdução
If your Nokia 6030’s keypad works inconsistently, you may need to replace the old keypad with a new one.
After extended use, cell phone keypads become unresponsive. A faulty keypad causes frustrating experiences when attempting to type something on the device or to call someone.
This guide provides step-by-step instructions on replacing your Nokia 6030’s keypad, without the need for any special skills or tools.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
Gently pull the rubber away from the front screen and the buttons will detach from the plastic case.
Uma outra pessoa concluiu este guia.
