Ir para o conteúdo principal
Nokia 6010 Keypad Replacement
O que você precisa
  1. Nokia 6010 Keypad Replacement, Battery: passo 1, imagem 1 %32 Nokia 6010 Keypad Replacement, Battery: passo 1, imagem 2 %32 Nokia 6010 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Keypad Replacement: passo 2, imagem 1 %32 Nokia 6010 Keypad Replacement: passo 2, imagem 2 %32
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Keypad Replacement, SIM Card: passo 3, imagem 1 %32
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Keypad Replacement, Keypad: passo 4, imagem 1 %32 Nokia 6010 Keypad Replacement, Keypad: passo 4, imagem 2 %32
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Keypad Replacement: passo 5, imagem 1 %32
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
Conclusão
Nicholas Hanne
Membro desde: 01/20/10
129 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 14-45, Regan Winter 2010 Membro de Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,054
