Introdução
If your Nokia 6 (identified with model number TA-1025) phone screen is not displaying properly, use this guide to replace your midframe. It’s a simple process and can be done fairly quickly.
You may need to replace your midframe if it is bent or is preventing you from using your screen in a functional manner.
Step 3 of this guide requires you to use a heat gun tool used to loosen the adhesive attached to the display. Read the directions and wear proper protective gear to avoid burning yourself.
Before starting your repair process, be sure to power off your phone completely and disconnect it from any external power source.
O que você precisa
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
Uma outra pessoa concluiu este guia.
