Ir para o conteúdo principal
Nokia 5310b XpressMusic Motherboard Replacement
O que você precisa
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: passo 2, imagem 1 %32 Nokia 5310b XpressMusic Motherboard Replacement: passo 2, imagem 2 %32
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, imagem 1 %32 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, imagem 2 %32 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, imagem 3 %32
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
  4. Nokia 5310b XpressMusic Motherboard Replacement: passo 4, imagem 1 %32 Nokia 5310b XpressMusic Motherboard Replacement: passo 4, imagem 2 %32
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: passo 6, imagem 1 %32 Nokia 5310b XpressMusic Motherboard Replacement: passo 6, imagem 2 %32
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic Motherboard Replacement: passo 7, imagem 1 %32
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic Motherboard Replacement: passo 8, imagem 1 %32 Nokia 5310b XpressMusic Motherboard Replacement: passo 8, imagem 2 %32
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
Conclusão
4 outras pessoas executaram este guia.
Max Kirby
Membro desde: 05/01/11
518 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 15-14, Regan Spring 2011 Membro de Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
Membros da 3
Autoria de 8 guias
Um comentário
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 6,841
