Ir para o conteúdo principal
Nokia 5310b XpressMusic Keypad Replacement
O que você precisa
  1. Nokia 5310b XpressMusic Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Keypad Replacement: passo 2, imagem 1 %32 Nokia 5310b XpressMusic Keypad Replacement: passo 2, imagem 2 %32
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
  3. Nokia 5310b XpressMusic Keypad Replacement, Keypad: passo 3, imagem 1 %32 Nokia 5310b XpressMusic Keypad Replacement, Keypad: passo 3, imagem 2 %32 Nokia 5310b XpressMusic Keypad Replacement, Keypad: passo 3, imagem 3 %32
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
  4. Nokia 5310b XpressMusic Keypad Replacement: passo 4, imagem 1 %32 Nokia 5310b XpressMusic Keypad Replacement: passo 4, imagem 2 %32
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
Conclusão
5 outras pessoas executaram este guia.
Max Kirby
Membro desde: 05/01/11
518 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 15-14, Regan Spring 2011 Membro de Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 93
Ao todo: 6,457
