Ir para o conteúdo principal
Nokia 3360 Cover Plate Replacement
  1. Nokia 3360 Cover Plate Replacement, Battery: passo 1, imagem 1 %32
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Cover Plate Replacement: passo 2, imagem 1 %32 Nokia 3360 Cover Plate Replacement: passo 2, imagem 2 %32
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Cover Plate Replacement: passo 3, imagem 1 %32 Nokia 3360 Cover Plate Replacement: passo 3, imagem 2 %32
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Cover Plate Replacement, Cover Plate: passo 4, imagem 1 %32 Nokia 3360 Cover Plate Replacement, Cover Plate: passo 4, imagem 2 %32
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
Conclusão
Kirk Gonzalez
Membro desde: 01/22/10
223 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-39, Regan Winter 2010 Membro de Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 2,668
