Introdução
This guide shows a step by step guide to fully access the keyboard, to clean it if it is sticking or completely replace the keypad if it is broken.
O que você precisa
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
5 outras pessoas executaram este guia.
