Introdução
This guide walks through the removal of the plastic frame of the phone. Removal of this provides access to the motherboard and most other components.
O que você precisa
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Uma outra pessoa concluiu este guia.
