Ir para o conteúdo principal
Nokia 3300B Motherboard Replacement
O que você precisa
  1. Nokia 3300B Motherboard Replacement, Battery: passo 1, imagem 1 %32 Nokia 3300B Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Motherboard Replacement: passo 2, imagem 1 %32 Nokia 3300B Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Motherboard Replacement, Keyboard: passo 3, imagem 1 %32 Nokia 3300B Motherboard Replacement, Keyboard: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Motherboard Replacement: passo 4, imagem 1 %32
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Motherboard Replacement: passo 5, imagem 1 %32
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
  6. Nokia 3300B Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Nokia 3300B Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the six Torx T6 screws from the phone's front case.
  7. Nokia 3300B Motherboard Replacement: passo 7, imagem 1 %32
    • Pull up on the front case containing the screen to separate it from the rest of the phone.
    • Gently lift the main board out of the back case.
Conclusão
3 outras pessoas executaram este guia.
Jose Quezada
Membro desde: 04/13/10
50 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-65, Johann Spring 2010 Membro de Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 2,912
