Pular para o conteúdo principal
Introdução
Use this guide to replace the keyboard of the Nokia 3300B.
Ferramentas
Nenhuma ferramenta especificada.
Peças
Nenhum componente especificado.
  1. Flip the Nokia 3300B over with the back-side facing towards you. Gently press the button on the back of the battery cover to release the cover and slide up.
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Lift the battery out of the back of the phone. It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Gently push the blue tabs on the top of the phone out of their slots. With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  5. With the screen still facing you, lift and remove the blue faceplate.
    • With the screen still facing you, lift and remove the blue faceplate.
  6. Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
Conclusão
2 outras pessoas concluíram este guia.
Chris Colwell
Membro desde: 13-04-2010
77 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 18-65, Johann Spring 2010 Membro de Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Membros
9 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 2,452
