Introdução
This guide directs the user to remove the battery of the Nokia 3120b. The battery is easily accessible as it is located directly under the back cover plate of the phone. A new battery can be installed the same way an old one is removed.
O que você precisa
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Uma outra pessoa concluiu este guia.
