Pular para o conteúdo principal
Introdução
This guide will disassemble the phone's cover plate and key pad to reveal the interface in order to work on the phone's speaker. This guide requires a moderate amount of work as the small parts are tricky to remove.
Peças
Nenhum componente especificado.
  1. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  5. Once the cover plate has been removed, the existing keypad should be easily removed. Once the cover plate has been removed, the existing keypad should be easily removed.
    • Once the cover plate has been removed, the existing keypad should be easily removed.
  6. Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone. Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
    • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
  7. Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
    • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
  8. To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
Conclusão
Uma outra pessoa concluiu este guia.
Pierre Tong
Membro desde: 11-03-2013
53 reputação
4 Guias de autoria
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membros
14 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 908
