Introdução
The SIM card is used to store information and it is well hidden under the battery. It is very easy to open once you know where it is.
O que você precisa
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
3 outras pessoas executaram este guia.
