Ir para o conteúdo principal
Nokia 3120 SIM Card Replacement
O que você precisa
  1. Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 1 %32 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 2 %32 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 3 %32
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 SIM Card Replacement: passo 2, imagem 1 %32
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
  4. Nokia 3120 SIM Card Replacement: passo 4, imagem 1 %32
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
Conclusão
3 outras pessoas executaram este guia.
Justin Emerson
Membro desde: 03/11/13
163 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
Membros da 3
Autoria de 14 guias
Um comentário
Thanks , appreciated.
Ian McCully - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 5,417
