Ir para o conteúdo principal
Nokia 3120 SIM Card Replacement
O que você precisa
  1. Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 1 %32 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 2 %32 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, imagem 3 %32
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 3120 SIM Card Replacement: passo 2, imagem 1 %32
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
    Pergunte ao FixBot
    Comentar
  3. Nokia 3120 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
    Pergunte ao FixBot
    Comentar
  4. Nokia 3120 SIM Card Replacement: passo 4, imagem 1 %32
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membros
Autoria de 14 guias
1Comentário do guia
Thanks , appreciated.
Ian McCully - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 50
Ao todo: 6,108
