Ir para o conteúdo principal
Nokia 3120 Liquid Crystal Display (LCD) Replacement
O que você precisa
  1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: passo 1, imagem 1 %32 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: passo 1, imagem 2 %32 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: passo 1, imagem 3 %32
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 2, imagem 1 %32
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: passo 3, imagem 1 %32 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: passo 3, imagem 2 %32 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: passo 3, imagem 3 %32
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): passo 4, imagem 1 %32
    • Once the cover plate has been removed, the keypad should easily pop out.
  5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 5, imagem 1 %32 Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 5, imagem 2 %32
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  6. Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 6, imagem 1 %32
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  7. Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 7, imagem 1 %32
    • Take out the cell phone electronic board
  8. Nokia 3120 Liquid Crystal Display (LCD) Replacement: passo 8, imagem 1 %32
    • The LCD screen can now be removed from the body of the phone.
Conclusão
Pierre Tong
Membro desde: 03/11/13
92 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 77
Ao todo: 1,756
