Introdução
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Peças
Não são necessárias peças.
  1. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Once the cover plate has been removed, the keypad should easily pop out.
    • Once the cover plate has been removed, the keypad should easily pop out.
  6. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  7. Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  8. Take out the cell phone electronic board
    • Take out the cell phone electronic board
  9. The LCD screen can now be removed from the body of the phone.
    • The LCD screen can now be removed from the body of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Pierre Tong
53 reputação
4 Guides authored
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membros
14 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Todo: 966
