Ir para o conteúdo principal
Nokia 3120 Keypad Replacement
  1. Nokia 3120 Keypad Replacement, Battery Installation: passo 1, imagem 1 %32 Nokia 3120 Keypad Replacement, Battery Installation: passo 1, imagem 2 %32 Nokia 3120 Keypad Replacement, Battery Installation: passo 1, imagem 3 %32
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 3120 Keypad Replacement: passo 2, imagem 1 %32
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
    Pergunte ao FixBot
    Comentar
  3. Nokia 3120 Keypad Replacement, Face Plate: passo 3, imagem 1 %32 Nokia 3120 Keypad Replacement, Face Plate: passo 3, imagem 2 %32 Nokia 3120 Keypad Replacement, Face Plate: passo 3, imagem 3 %32
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    Pergunte ao FixBot
    Comentar
  4. Nokia 3120 Keypad Replacement, Keypad: passo 4, imagem 1 %32
    • Once the cover plate has been removed, the existing keypad should be easily removed.
    • To install a new keypad, simply place the new keypad in the same place where the old keypad was.
    Pergunte ao FixBot
    Comentar
Conclusão
Pierre Tong
Membro desde: 03/11/13
92 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 13-2, Benson Spring 2013 Membro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 64
Ao todo: 1,112
