Ir para o conteúdo principal
Nokia 3100b Screen Replacement
O que você precisa
  1. Nokia 3100b Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: passo 2, imagem 1 %32
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: passo 3, imagem 1 %32
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: passo 4, imagem 1 %32
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: passo 5, imagem 1 %32
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: passo 6, imagem 1 %32
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: passo 7, imagem 1 %32
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: passo 8, imagem 1 %32
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: passo 9, imagem 1 %32
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: passo 10, imagem 1 %32
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: passo 11, imagem 1 %32
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 29-64, Johann Spring 2010 Membro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 95
Ao todo: 2,143
