Ir para o conteúdo principal
Nokia 2630b LCD Display Replacement
O que você precisa
  1. Nokia 2630b LCD Display Replacement, LCD Display: passo 1, imagem 1 %32 Nokia 2630b LCD Display Replacement, LCD Display: passo 1, imagem 2 %32 Nokia 2630b LCD Display Replacement, LCD Display: passo 1, imagem 3 %32
    • Remove the Back cover by Pressing the release buttons located on either side of the battery cover
    • Now Remove The Battery and Simcard from the slots
  2. Nokia 2630b LCD Display Replacement: passo 2, imagem 1 %32 Nokia 2630b LCD Display Replacement: passo 2, imagem 2 %32 Nokia 2630b LCD Display Replacement: passo 2, imagem 3 %32
    • Remove the two screws on either side of the back side using the microscrewdriver using the T5 bit
    • Now Remove the Front key panel from the Main Board Carefully using the Plastic Opening Tools
  3. Nokia 2630b LCD Display Replacement: passo 3, imagem 1 %32 Nokia 2630b LCD Display Replacement: passo 3, imagem 2 %32 Nokia 2630b LCD Display Replacement: passo 3, imagem 3 %32
    • Now Remove the four screws in the front side of the main board
    • Now push the Board from the Battery slot side and carefully By using the Plastic Opening Tools Separate the board from the back case or rear case
  4. Nokia 2630b LCD Display Replacement: passo 4, imagem 1 %32 Nokia 2630b LCD Display Replacement: passo 4, imagem 2 %32
    • Now Gently Separate the lock at the right side to remove the outer cover of the Main Board
    • !!!! Be Cautious that the key panel is attached at the other end
  5. Nokia 2630b LCD Display Replacement: passo 5, imagem 1 %32 Nokia 2630b LCD Display Replacement: passo 5, imagem 2 %32 Nokia 2630b LCD Display Replacement: passo 5, imagem 3 %32
    • Remove the Chip which is attached to the main board
    • Now we can separate the display from the main board and we can replace it with the new display.
Conclusão
LOGESAM
Membro desde: 12/28/15
123 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 462
