Ir para o conteúdo principal
Nokia 2630b Back Case Replacement
O que você precisa
  1. Nokia 2630b Back Case Replacement, Battery Case: passo 1, imagem 1 %32 Nokia 2630b Back Case Replacement, Battery Case: passo 1, imagem 2 %32
    • Press and the release button on both sides of the battery cover. While holding down the release buttons pull the battery cover away from the phone
  2. Nokia 2630b Back Case Replacement: passo 2, imagem 1 %32
    • Pull out the battery by holding the top of the battery and tilting out.
  3. Nokia 2630b Back Case Replacement, Screen / Front Case: passo 3, imagem 1 %32
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Back Case Replacement: passo 4, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 4, imagem 2 %32 Nokia 2630b Back Case Replacement: passo 4, imagem 3 %32
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Back Case Replacement: passo 5, imagem 1 %32
    • Remove screws using the same T5 screw bit to release the computer chip from the case
    • Keep the screws in a safe place while you continue working
  6. Nokia 2630b Back Case Replacement: passo 6, imagem 1 %32
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Back Case Replacement: passo 7, imagem 1 %32
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Back Case Replacement: passo 8, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 8, imagem 2 %32
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Back Case Replacement: passo 9, imagem 1 %32
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Back Case Replacement: passo 10, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 10, imagem 2 %32
    • Place computer chip and screen back into black case
  11. Nokia 2630b Back Case Replacement: passo 11, imagem 1 %32
    • Place black frame back over screen
  12. Nokia 2630b Back Case Replacement: passo 12, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 12, imagem 2 %32
    • Carefully place keypad back in place
  13. Nokia 2630b Back Case Replacement: passo 13, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 13, imagem 2 %32
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Back Case Replacement: passo 14, imagem 1 %32
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Back Case Replacement: passo 15, imagem 1 %32
    • Slide battery back into place
  16. Nokia 2630b Back Case Replacement: passo 16, imagem 1 %32
    • Snap battery cover back into place
  17. Nokia 2630b Back Case Replacement, Back Case: passo 17, imagem 1 %32 Nokia 2630b Back Case Replacement, Back Case: passo 17, imagem 2 %32
    • Locate the four screws that secure the back case to the rest of the phone.
    • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  18. Nokia 2630b Back Case Replacement: passo 18, imagem 1 %32 Nokia 2630b Back Case Replacement: passo 18, imagem 2 %32 Nokia 2630b Back Case Replacement: passo 18, imagem 3 %32
    • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
    • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eric
Membro desde: 04/07/11
57 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-61, Walters Spring 2011 Membro de Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 2,098
