Introdução
This guide will show you how to replace the LCD screen for the phone.
O que você precisa
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
