Peças
Não são necessárias peças.
  1. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
Conclusão
Jeff Carter
91 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-52, Amido Fall 2010 Membro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membros
12 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,896
