Ir para o conteúdo principal
Nokia 2610 Front Pannel Replacement
O que você precisa
  1. Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, imagem 1 %32 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, imagem 2 %32 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, imagem 3 %32
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    Pergunte ao FixBot
    Comentar
  2. Nokia 2610 Front Pannel Replacement: passo 2, imagem 1 %32 Nokia 2610 Front Pannel Replacement: passo 2, imagem 2 %32 Nokia 2610 Front Pannel Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia 2610 Front Pannel Replacement: passo 3, imagem 1 %32 Nokia 2610 Front Pannel Replacement: passo 3, imagem 2 %32 Nokia 2610 Front Pannel Replacement: passo 3, imagem 3 %32
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    Pergunte ao FixBot
    Comentar
  4. Nokia 2610 Front Pannel Replacement, Front Pannel: passo 4, imagem 1 %32 Nokia 2610 Front Pannel Replacement, Front Pannel: passo 4, imagem 2 %32
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    Pergunte ao FixBot
    Comentar
  5. Nokia 2610 Front Pannel Replacement: passo 5, imagem 1 %32 Nokia 2610 Front Pannel Replacement: passo 5, imagem 2 %32
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Andrew Wood
Membro desde: 10/05/10
336 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-52, Amido Fall 2010 Membro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 2,471
