Ir para o conteúdo principal
Nokia 2610 Battery and Sim Card Replacement
O que você precisa
  1. Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: passo 1, imagem 1 %32 Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: passo 1, imagem 2 %32 Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: passo 1, imagem 3 %32
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Battery and Sim Card Replacement: passo 2, imagem 1 %32 Nokia 2610 Battery and Sim Card Replacement: passo 2, imagem 2 %32 Nokia 2610 Battery and Sim Card Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Battery and Sim Card Replacement: passo 3, imagem 1 %32 Nokia 2610 Battery and Sim Card Replacement: passo 3, imagem 2 %32 Nokia 2610 Battery and Sim Card Replacement: passo 3, imagem 3 %32
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 7-52, Amido Fall 2010 Membro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 101
Ao todo: 7,008
