Peças
Não são necessárias peças.
Be sure cell phone is off before you begin to disassemble the phone.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Adicionar comentário
Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • With the faceplate removed, simply peel off rubber key pad and remove.
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
  • Locate the two plastic LCD unit hooks.
  • Pry hooks outward.
  • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Conclusão
Andres Echeverria
4 reputação
6 Guides authored
Equipe
Cal Poly, Team 20-8, Maness Fall 2010 Membro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Membros
28 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 189
