Ir para o conteúdo principal
Nokia 2128i Charging Port Replacement
O que você precisa
  1. Nokia 2128i Charging Port Replacement, Battery: passo 1, imagem 1 %32 Nokia 2128i Charging Port Replacement, Battery: passo 1, imagem 2 %32 Nokia 2128i Charging Port Replacement, Battery: passo 1, imagem 3 %32
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Charging Port Replacement: passo 2, imagem 1 %32 Nokia 2128i Charging Port Replacement: passo 2, imagem 2 %32 Nokia 2128i Charging Port Replacement: passo 2, imagem 3 %32
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Charging Port Replacement, Faceplate: passo 3, imagem 1 %32 Nokia 2128i Charging Port Replacement, Faceplate: passo 3, imagem 2 %32 Nokia 2128i Charging Port Replacement, Faceplate: passo 3, imagem 3 %32
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Charging Port Replacement, Keypad: passo 4, imagem 1 %32 Nokia 2128i Charging Port Replacement, Keypad: passo 4, imagem 2 %32 Nokia 2128i Charging Port Replacement, Keypad: passo 4, imagem 3 %32
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Charging Port Replacement, Motherboard Assembly: passo 5, imagem 1 %32 Nokia 2128i Charging Port Replacement, Motherboard Assembly: passo 5, imagem 2 %32 Nokia 2128i Charging Port Replacement, Motherboard Assembly: passo 5, imagem 3 %32
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Charging Port Replacement: passo 6, imagem 1 %32 Nokia 2128i Charging Port Replacement: passo 6, imagem 2 %32 Nokia 2128i Charging Port Replacement: passo 6, imagem 3 %32
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Charging Port Replacement, Charging Port: passo 7, imagem 1 %32 Nokia 2128i Charging Port Replacement, Charging Port: passo 7, imagem 2 %32
    • With the logic board and LCD unit removed, gently pry out the charging port.
Conclusão
Curtis Lutje
Membro desde: 10/07/10
28 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-8, Maness Fall 2010 Membro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,933
