Ir para o conteúdo principal
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
O que você precisa
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: passo 1, imagem 1 %32 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: passo 1, imagem 2 %32
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: passo 2, imagem 1 %32
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: passo 3, imagem 1 %32 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: passo 3, imagem 2 %32
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
    You please Nokia 1100 Motherboard and keyboard Rely
    ajay gupta - Responder
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: passo 4, imagem 1 %32 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: passo 4, imagem 2 %32
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Conclusão
12 outras pessoas executaram este guia.
James Szelenyi
Membro desde: 04/19/13
262 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-43, Amido Spring 2013 Membro de Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
Membros da 4
Autoria de 14 guias
Um comentário
you nokia 1100 mother board please soon date…?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 4,242
