Introdução
This guide will show you step by step how to access the speaker. If your speaker is no longer working this guide can help you to replace the speaker. Additionally this guide can help you to access the speaker to make sure that the speaker is connected properly.
O que você precisa
Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
Insert tweezers into the small crevices of the backside of the speaker, and lift upwards.
4 outras pessoas executaram este guia.
