Introdução
This guide will help you to access the screen if you have cracked it and want to replace the whole screen. Additionally this guide can help you to access the screen if your screen is not turning on to check to see if the screen is attached properly. This guide will give you step by step instructions on how to take the device apart in order to access the screen.
O que você precisa
Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
9 outras pessoas executaram este guia.
