Introdução
This guide will give you step by step instructions on how to replace the motherboard. If you are having technical difficulties and this is may be related to the motherboard, this guide will give you full access to the motherboard system.
O que você precisa
Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
12 outras pessoas executaram este guia.
