Introdução
If you are having trouble with the USB port or solar panel, then these steps should be used to replace it altogether.
O que você precisa
Turn over the device so that the back of the device is facing up.
Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
Quase terminado!
Conclusão
Uma outra pessoa concluiu este guia.
