Ir para o conteúdo principal
Nokero SunRay Pro Power Panel USB Assembly Replacement
O que você precisa
  1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: passo 1, imagem 1 %32
    • Turn over the device so that the back of the device is facing up.
    Pergunte ao FixBot
    Comentar
  2. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, imagem 1 %32 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, imagem 2 %32 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, imagem 3 %32
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    Pergunte ao FixBot
    Comentar
  3. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 3, imagem 1 %32 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 3, imagem 2 %32
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    Pergunte ao FixBot
    Comentar
  4. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 4, imagem 1 %32 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 4, imagem 2 %32
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    Pergunte ao FixBot
    Comentar
  5. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: passo 5, imagem 1 %32 Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: passo 5, imagem 2 %32
    • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Orr
Membro desde: 01/20/15
229 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 498
