Ir para o conteúdo principal
Nokero SunRay Pro Power Panel Front and Back Case Replacement
O que você precisa
  1. Nokero SunRay Pro Power Panel Front and Back Case Replacement, Front and Back Case: passo 1, imagem 1 %32
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 2, imagem 1 %32 Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 2, imagem 2 %32 Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 2, imagem 3 %32
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 3, imagem 1 %32 Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 3, imagem 2 %32
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 4, imagem 1 %32 Nokero SunRay Pro Power Panel Front and Back Case Replacement: passo 4, imagem 2 %32
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy
Membro desde: 01/21/15
157 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-3, Blackwell Winter 2015 Membro de USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 210
