Ir para o conteúdo principal
Nokero Shavano N220 Batteries Replacement
O que você precisa
    1. Nokero Shavano N220 Batteries Replacement, Batteries: passo 1, imagem 1 %32 Nokero Shavano N220 Batteries Replacement, Batteries: passo 1, imagem 2 %32 Nokero Shavano N220 Batteries Replacement, Batteries: passo 1, imagem 3 %32
      • Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
      Pergunte ao FixBot
      Comentar
    2. Nokero Shavano N220 Batteries Replacement: passo 2, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 2, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 2, imagem 3 %32
      • Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
      Pergunte ao FixBot
      Comentar
    3. Nokero Shavano N220 Batteries Replacement: passo 3, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 3, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 3, imagem 3 %32
      • Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up.
      • You only need to apply minimal pressure to lift the cover. If you force it too hard, you may snap the plastic.
      • Repeat for the second battery cover.
      Pergunte ao FixBot
      Comentar
    4. Nokero Shavano N220 Batteries Replacement: passo 4, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 4, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 4, imagem 3 %32
      • Use a spudger or your fingers to remove the two batteries.
      Pergunte ao FixBot
      Comentar
    5. Nokero Shavano N220 Batteries Replacement: passo 5, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 5, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 5, imagem 3 %32
      • Now take your new batteries or let the old ones charge and reinsert them.
      • Follow the picture of the battery on the inside of the device.
      Pergunte ao FixBot
      Comentar
    6. Nokero Shavano N220 Batteries Replacement: passo 6, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 6, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 6, imagem 3 %32
      • Once you have put in both sides, insert the covers.
      • Match the ends and it should just pop into place.
      Pergunte ao FixBot
      Comentar
    7. Nokero Shavano N220 Batteries Replacement: passo 7, imagem 1 %32 Nokero Shavano N220 Batteries Replacement: passo 7, imagem 2 %32 Nokero Shavano N220 Batteries Replacement: passo 7, imagem 3 %32
      • Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in.
      • Take the lid and turn it counter clockwise using your index finger and thumb.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 65
Ao todo: 819
