Introdução
Are your batteries dead? With this guide, you will know learn how to easily replace the batteries in your Nokero Shavano N220.
Peças
Não são necessárias peças.
  1. Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb. Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb. Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
    • Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
  2. Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device. Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device. Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
    • Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
  3. Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up. You only need to apply minimal pressure to lift the cover. If you force it too hard, you may snap the plastic. Repeat for the second battery cover.
    • Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up.
      • You only need to apply minimal pressure to lift the cover. If you force it too hard, you may snap the plastic.
    • Repeat for the second battery cover.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Use a spudger or your fingers to remove the two batteries. Use a spudger or your fingers to remove the two batteries. Use a spudger or your fingers to remove the two batteries.
    • Use a spudger or your fingers to remove the two batteries.
  6. Now take your new batteries or let the old ones charge and reinsert them. Follow the picture of the battery on the inside of the device. Follow the picture of the battery on the inside of the device.
    • Now take your new batteries or let the old ones charge and reinsert them.
    • Follow the picture of the battery on the inside of the device.
  7. Once you have put in both sides, insert the covers. Match the ends and it should just pop into place. Match the ends and it should just pop into place.
    • Once you have put in both sides, insert the covers.
    • Match the ends and it should just pop into place.
  8. Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in. Take the lid and turn it counter clockwise using your index finger and thumb. Take the lid and turn it counter clockwise using your index finger and thumb.
    • Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in.
    • Take the lid and turn it counter clockwise using your index finger and thumb.
Conclusão
Uma outra pessoa concluiu este guia.
Erica Hill
523 reputação
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 198
