Ir para o conteúdo principal
Nokero N400 Switch Replacement
O que você precisa
    1. Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, imagem 1 %32 Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, imagem 2 %32 Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, imagem 3 %32
      • Press down firmly to remove the battery cover and display battery.
      • Then remove the battery.
      Pergunte ao FixBot
      Comentar
    2. Nokero N400 Switch Replacement, Unscrew Back Cover: passo 2, imagem 1 %32 Nokero N400 Switch Replacement, Unscrew Back Cover: passo 2, imagem 2 %32
      • Remove the 7mm Phillips #1 screw.
      Pergunte ao FixBot
      Comentar
    3. Nokero N400 Switch Replacement, Pry Open Back Cover: passo 3, imagem 1 %32 Nokero N400 Switch Replacement, Pry Open Back Cover: passo 3, imagem 2 %32
      • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
      • Unlatch the clips on the inside and pull device apart.
      • Some clips will break when forced open.
      Pergunte ao FixBot
      Comentar
    1. Nokero N400 Switch Replacement, Remove Switch From Housing: passo 4, imagem 1 %32
      • Using a spudger carefully pry switch from housing.
      Pergunte ao FixBot
      Comentar
    2. Nokero N400 Switch Replacement, Cut Old Switch Free: passo 5, imagem 1 %32
      • Use wire cutters to cut the two black wires attached to the old switch.
      • You must use a splicer or a soldering gun to reattach the wires of the new switch.
      • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
      Pergunte ao FixBot
      Comentar
Conclusão
Benjamin franklin
Membro desde: 01/20/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membros
Autoria de 60 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 60
Ao todo: 599
