Ir para o conteúdo principal
Nokero N400 Solar Panel Replacement
O que você precisa
  1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: passo 1, imagem 1 %32 Nokero N400 Solar Panel Replacement, Remove Battery Cover: passo 1, imagem 2 %32 Nokero N400 Solar Panel Replacement, Remove Battery Cover: passo 1, imagem 3 %32
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: passo 2, imagem 1 %32 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: passo 2, imagem 2 %32
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: passo 3, imagem 1 %32 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: passo 3, imagem 2 %32
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Solar Panel Replacement, Solar Panel: passo 4, imagem 1 %32 Nokero N400 Solar Panel Replacement, Solar Panel: passo 4, imagem 2 %32
    • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
    • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
    • For reassembly you will need to either splice, or solder the wires onto the replacement.
Conclusão
Daniel Bumiller
Membro desde: 01/20/15
201 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 331
