Ir para o conteúdo principal
Nokero N400 LED Panel Replacement
O que você precisa
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: passo 1, imagem 1 %32 Nokero N400 LED Panel Replacement, Remove Battery Cover: passo 1, imagem 2 %32 Nokero N400 LED Panel Replacement, Remove Battery Cover: passo 1, imagem 3 %32
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: passo 2, imagem 1 %32 Nokero N400 LED Panel Replacement, Unscrew Back Cover: passo 2, imagem 2 %32
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: passo 3, imagem 1 %32 Nokero N400 LED Panel Replacement, Pry Open Back Cover: passo 3, imagem 2 %32
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: passo 4, imagem 1 %32 Nokero N400 LED Panel Replacement, Removing the LED Panel: passo 4, imagem 2 %32
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: passo 5, imagem 1 %32
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Burwell
Membro desde: 01/20/15
173 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 399
